Ana içeriğe geç
Apple Studio Display M7649 Inverter Replacement
Neye ihtiyacın var
  1. Apple Studio Display M7649 Inverter Replacement, Stand: adım 1, 2 resimden 1. Apple Studio Display M7649 Inverter Replacement, Stand: adım 1, 2 resimden 2.
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    FixBot'a Sor
    Yorum Ekle
  2. Apple Studio Display M7649 Inverter Replacement, Panels: adım 2, 1 resimden 1.
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    FixBot'a Sor
    Yorum Ekle
  3. Apple Studio Display M7649 Inverter Replacement: adım 3, 1 resimden 1.
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
    FixBot'a Sor
    Yorum Ekle
  4. Apple Studio Display M7649 Inverter Replacement: adım 4, 1 resimden 1.
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    FixBot'a Sor
    Yorum Ekle
  5. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: adım 5, 1 resimden 1.
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    FixBot'a Sor
    Yorum Ekle
  6. Apple Studio Display M7649 Inverter Replacement: adım 6, 1 resimden 1.
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
    FixBot'a Sor
    Yorum Ekle
  7. Apple Studio Display M7649 Inverter Replacement: adım 7, 2 resimden 1. Apple Studio Display M7649 Inverter Replacement: adım 7, 2 resimden 2.
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
    FixBot'a Sor
    Yorum Ekle
  8. Apple Studio Display M7649 Inverter Replacement, Inverter: adım 8, 1 resimden 1.
    • Remove these three screws holding the board to the display
    FixBot'a Sor
    Yorum Ekle
  9. Apple Studio Display M7649 Inverter Replacement: adım 9, 1 resimden 1.
    • Remove these five cables connection the inverter to the backlights and logic board.
    • Taking note where they connect to for reassembly
    FixBot'a Sor
    Yorum Ekle
  10. Apple Studio Display M7649 Inverter Replacement: adım 10, 1 resimden 1.
    • Remove and replace the inverter
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Andrew Tsao
186 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G20
4 Üyeler
31 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 47
Her zaman: 7,872
