Giriş
How to remove and replace the logic board. The logic board is like the main cpu of the display.
Neye ihtiyacın var
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
2 farklı kişi bu kılavuzu tamamladı.
