Ana içeriğe geç
Apple Studio Display M7649 Rear Panel Replacement
Neye ihtiyacın var
  1. Apple Studio Display M7649 Rear Panel Replacement, Stand: adım 1, 2 resimden 1. Apple Studio Display M7649 Rear Panel Replacement, Stand: adım 1, 2 resimden 2.
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Rear Panel Replacement, Panels: adım 2, 1 resimden 1.
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Rear Panel Replacement: adım 3, 1 resimden 1.
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Rear Panel Replacement: adım 4, 1 resimden 1.
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Alan Truong
566 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-20, Maness Winter 2010 Cal Poly, Team 3-20, Maness Winter 2010 üyesi
CPSU-MANESS-W10S3G20
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 3,701
