Ana içeriğe geç
Apple TV 1st Generation AirPort Card Replacement
Neye ihtiyacın var
  1. Apple TV 1st Generation AirPort Card Replacement, Lower Case: adım 1, 1 resimden 1.
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation AirPort Card Replacement: adım 2, 1 resimden 1.
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation AirPort Card Replacement: adım 3, 1 resimden 1.
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation AirPort Card Replacement: adım 4, 2 resimden 1. Apple TV 1st Generation AirPort Card Replacement: adım 4, 2 resimden 2.
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
  5. Apple TV 1st Generation AirPort Card Replacement, AirPort Card: adım 5, 1 resimden 1.
    • Pry the AirPort antenna cables straight up from their sockets on the logic board.
  6. Apple TV 1st Generation AirPort Card Replacement: adım 6, 1 resimden 1.
    • Remove the single T8 Torx screw securing the AirPort card to the logic board.
  7. Apple TV 1st Generation AirPort Card Replacement: adım 7, 1 resimden 1.
    • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
ropel
119 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G5
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 13,498
