Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Remove the four T10 Torx screws that secure the lower case to the upper case.
Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
Carefully pull the hard drive data cable straight up from its socket on the logic board.
Pry the AirPort antenna cables straight up from their sockets on the logic board.
Remove the single T8 Torx screw securing the AirPort card to the logic board.
Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
11 farklı kişi bu kılavuzu tamamladı.
