Ana içeriğe geç
Giriş
Remove the lower case in your Apple TV 1st Generation.
Parçalar
Hiçbir parça belirtilmedi.
  1. Flip the Apple TV over so that the bottom of the unit is facing up.
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Remove the four T10 Torx screws that secure the lower case to the upper case.
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  5. Carefully pull the hard drive data cable straight up from its socket on the logic board. During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
CCarvalho
223 İtibar
1 Kılavuz yazıldı
Takım
Cal Poly, Team 18-5, Maness Fall 2009 Cal Poly, Team 18-5, Maness Fall 2009 üyesi
CPSU-MANESS-F09S18G5
5 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
This guide may make more sense as a teardown, since its not really showing any repairs or replacements.
Alex Jansen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 8
Her zaman: 7,914
