Ana içeriğe geç
Apple TV 2nd Generation Bottom Cover Replacement
Neye ihtiyacın var
  1. Apple TV 2nd Generation Bottom Cover Replacement, Bottom Cover: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Metal Spudger
    $2.99
    Satın Al
    • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
  2. Apple TV 2nd Generation Bottom Cover Replacement: adım 2, 1 resimden 1.
    • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
Sonuç
Areej Bashawiri
201 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 1,141
