Ana içeriğe geç
Apple TV 2nd Generation Power Supply Replacement
Neye ihtiyacın var
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: adım 1, 2 resimden 1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Metal Spudger
    $2.99
    Satın Al
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: adım 2, 3 resimden 1. Apple TV 2nd Generation Power Supply Replacement: adım 2, 3 resimden 2. Apple TV 2nd Generation Power Supply Replacement: adım 2, 3 resimden 3.
    Phillips #1 Screwdriver
    $5.49
    Satın Al
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: adım 3, 2 resimden 1. Apple TV 2nd Generation Power Supply Replacement: adım 3, 2 resimden 2.
    Satın Al
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: adım 4, 2 resimden 1. Apple TV 2nd Generation Power Supply Replacement: adım 4, 2 resimden 2.
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Deanna Rice
261 İtibar
2 adet Kılavuz yazıldı
Ekip
2 Yorum
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Yanıt
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 1,755
