Ana içeriğe geç
Apple TV 3rd Generation Logic Board Replacement
Neye ihtiyacın var
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: adım 1, 1 resimden 1.
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    where so i find a new base to replace it with
    sharpeEZz - Yanıt
  2. Apple TV 3rd Generation Logic Board Replacement: adım 2, 1 resimden 1.
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: adım 3, 1 resimden 1.
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: adım 4, 2 resimden 1. Apple TV 3rd Generation Logic Board Replacement: adım 4, 2 resimden 2.
    • Disconnect the power supply connector from the logic board with a spudger.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Vincent Monteil
6.975 İtibar
19 adet Kılavuz yazıldı
4 Yorum
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - Yanıt
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - Yanıt
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 9,680
