Ana içeriğe geç
Apple TV 3rd Generation Status LED Replacement
Neye ihtiyacın var
  1. Apple TV 3rd Generation Status LED Replacement, Snap-on Base: adım 1, 1 resimden 1.
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Status LED Replacement: adım 2, 1 resimden 1.
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Status LED Replacement, Logic Board: adım 3, 1 resimden 1.
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Status LED Replacement: adım 4, 2 resimden 1. Apple TV 3rd Generation Status LED Replacement: adım 4, 2 resimden 2.
    • Disconnect the power supply connector from the logic board with a spudger.
  5. Apple TV 3rd Generation Status LED Replacement, Power Supply: adım 5, 2 resimden 1. Apple TV 3rd Generation Status LED Replacement, Power Supply: adım 5, 2 resimden 2.
    • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • Do not pull the wires to remove the power supply. The connector is fragile.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
  6. Apple TV 3rd Generation Status LED Replacement, Status LED: adım 6, 2 resimden 1. Apple TV 3rd Generation Status LED Replacement, Status LED: adım 6, 2 resimden 2.
    • The last remaining part in the Apple TV is the status LED. You can remove this part with your plastic spudger.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Vincent Monteil
7.023 İtibar
19 adet Kılavuz yazıldı
1Rehber Yorum
Step 2: “caring not to break….”. Thanks, great guide. David
David Apimerika - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 3,297
