Ana içeriğe geç
Apple TV 4K Remote Logic Board Replacement
Neye ihtiyacın var
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: adım 1, 1 resimden 1.
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: adım 2, 2 resimden 1. Apple TV 4K Remote Logic Board Replacement: adım 2, 2 resimden 2.
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: adım 3, 1 resimden 1.
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: adım 4, 2 resimden 1. Apple TV 4K Remote Logic Board Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: adım 5, 1 resimden 1.
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: adım 6, 2 resimden 1. Apple TV 4K Remote Logic Board Replacement: adım 6, 2 resimden 2.
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: adım 7, 1 resimden 1.
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: adım 8, 1 resimden 1.
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Keenan Barber
1.270 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018 üyesi
UWSTOUT-OGDEN-F18S6G3
4 Üyeler
15 adet Kılavuz yazıldı
2 Yorum
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Yanıt
I can’t find replacement adhesive that fits. How are people getting this thing to stick back together when you’re done??
Jeremy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 65
Son 30 gün: 191
Her zaman: 6,055
