Ana içeriğe geç
Apple Thunderbolt Display Fan Replacement
Neye ihtiyacın var
  1. Apple Thunderbolt Display Fan Replacement, LCD: adım 1, 3 resimden 1. Apple Thunderbolt Display Fan Replacement, LCD: adım 1, 3 resimden 2. Apple Thunderbolt Display Fan Replacement, LCD: adım 1, 3 resimden 3.
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
  2. Apple Thunderbolt Display Fan Replacement: adım 2, 2 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 2, 2 resimden 2.
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
  3. Apple Thunderbolt Display Fan Replacement: adım 3, 2 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 3, 2 resimden 2.
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
  4. Apple Thunderbolt Display Fan Replacement: adım 4, 3 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 4, 3 resimden 2. Apple Thunderbolt Display Fan Replacement: adım 4, 3 resimden 3.
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
  5. Apple Thunderbolt Display Fan Replacement: adım 5, 3 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 5, 3 resimden 2. Apple Thunderbolt Display Fan Replacement: adım 5, 3 resimden 3.
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
  6. Apple Thunderbolt Display Fan Replacement: adım 6, 3 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 6, 3 resimden 2. Apple Thunderbolt Display Fan Replacement: adım 6, 3 resimden 3.
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
  7. Apple Thunderbolt Display Fan Replacement: adım 7, 1 resimden 1.
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
  8. Apple Thunderbolt Display Fan Replacement: adım 8, 2 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 8, 2 resimden 2.
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
  9. Apple Thunderbolt Display Fan Replacement, Fan: adım 9, 1 resimden 1.
    • Now you should have access to the rest of the display. From here, locate the fan.
  10. Apple Thunderbolt Display Fan Replacement: adım 10, 3 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 10, 3 resimden 2. Apple Thunderbolt Display Fan Replacement: adım 10, 3 resimden 3.
    • The fan is connected to the main logic board by two connectors. Make sure that while disconnecting them, grab the wire at the point closest to the board and the pull slowly to avoid damaging the connectors.
    • Remove the piece of tape that is holding the wires to the casing.
  11. Apple Thunderbolt Display Fan Replacement: adım 11, 2 resimden 1. Apple Thunderbolt Display Fan Replacement: adım 11, 2 resimden 2.
    • Next, you can see that the fan is connected to the casing by three screws.
    • Use the TR 10 screwdriver to remove these three screws.
  12. Apple Thunderbolt Display Fan Replacement: adım 12, 1 resimden 1.
    • Make sure to carefully remove the fan after it is free of the casing as to not damage surrounding parts.
    • Switch out the old fan with the new one and you're all set!
Sonuç
28 farklı kişi bu kılavuzu tamamladı.
Calvin Laverty
2.268 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-11, Maness Spring 2015 Cal Poly, Team 5-11, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G11
4 Üyeler
20 adet Kılavuz yazıldı
11Kılavuz Yorumları
I have been having trouble with fan noise -- a noisy, rapid thumping sound, especially on startup but getting worse over a few weeks and lately persisting all day. Following this excellent guide, I removed the fan and examined it. I could see nothing wrong except perhaps a fine layer of dust on the blades, no worse than could be expected. I did not manage to disassemble the fan itself, as its two-part housing is very firmly clipped together, but applied a vacuum cleaner hose to both the entry and exit sides to clean it up as much as possible. I put it back and reassembled the whole display, and am pleased to report that the noise has completely disappeared. This may be good news to anyone dismayed by the apparent non-availability of replacement fans.
John Canti - Yanıt
Thank you for your comment. Experienced the same trouble, it sounded much like the washing machine spinning at the neighbors while it wasn't. Managed to get the fan out, same as you wrote, some dust, not much. Managed to open the fan housing, but not without breaking some of the clips that kept it together. I took the fan out, cleaned it carefully with a long haired brush on a vacuum cleaner. Have not touched the brush-less copper part. Put it back together and closed the fan casing. I then applied some clear tape where the clips broke in order to keep the housing 'sealed'. Put the LCD back in, connected all the wires. Then put the glass front back on top, but without the Torx screws :-( I just wanted to test whether or not the noise was gone. It was a bit nerve wrecking to remove the glass again, without pulling out the LCD display. Anyway, screws back in place, and all is quiet as it was when I bought it second hand, a few weeks ago as for my Mac Mini. Fingers crossed that it will last some time for me!
sabofixit -
This guide made the power supply replacement quick and easy.
Jon Martinez - Yanıt
I had the rumbling fan cleaned by a pro. but the rattling didn't go. I just finished replacing the fan on my 27'' Thunderbolt Display using these instructions, and so far so good after 3 hours. It usually started the rattling after 30mn!
I purchased the fan on eBay. There were a couple available then.
I got the fan for $18 and spent 30mn on the job. At the Apple certified spot in town, they were going to charge me $250! I bought this Apple Display second hand for $250! and now it is back to its old self, working like a charm :)
Thank you very much for this web page which walked me through the process.
By the way, for a succion cup I used the two small ones that are attached to my soap holder, from the bathroom tiled wall; worked just fine and I didn't have to spend $20 to buy one.
cheers
ekoh dubois - Yanıt
Many thanks to Mr. Laverty and the other contributors. I followed this guide to install a new power supply in my darkened 27” Thunderbolt Display to bring it back from the dead. While the instructions were specifically for replacing the fan, I found that after following them to remove the LCD panel, it was easy to replace the power supply as well. For anyone else who may suspect a failed power supply (loud buzzing and then black), I ordered mine directly from China, supposedly a brand new one. It looks identical to the original in every way and does have a 2018 sticker affixed to it. It took a month to arrive but did the trick. I paid $70.50 for it from wwon_one off eBay (https://www.ebay.com/itm/273134311780). Thanks again for the extremely helpful guide!
ilovemybeagles - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 75
Son 30 gün: 395
Her zaman: 24,877
