Ana içeriğe geç
Apple Time Capsule Model A1254 - Replacing the power supply capacitors
Neye ihtiyacın var
  1. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Open the Time Capsule: adım 1, 1 resimden 1.
    • Using the fingers or a blunt, plastic tool, peel away the rubber base.
    • Be careful as in some older Time Capsules, it may be that the rubber base is torn. Please perform the step slowly and with care.
  2. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Accessing the Power Board: adım 2, 1 resimden 1.
    • Remove the 7 marked screws in order to remove the aluminum bottom and free the power supply board.
    • Once the bottom is removed, disconnect the fan cord from the motherboard.
  3. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Disconnect the power supply board: adım 3, 1 resimden 1.
    • The power supply board is not held in by any screws (removed in the previous step).
    • Disconnect the SATA power connector from the drive, the connector from the motherboard, and the power plug.
    • Gently pull out the power supply board.
  4. Apple Time Capsule Model A1254 - Replacing the power supply capacitors: adım 4, 2 resimden 1. Apple Time Capsule Model A1254 - Replacing the power supply capacitors: adım 4, 2 resimden 2.
    • Gently peel off the aluminum tape on the label side, then pull it aside.
    • Insert translation here
  5. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Identify broken capacitor: adım 5, 2 resimden 1. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Identify broken capacitor: adım 5, 2 resimden 2.
    • Once the card is out and the capacitors are visible, you have to look for those which are bulging.
    • The second photo is not of good quality, but it is the one on the left which is bulging.
    • In any case, you must replace the capacitors by pair. Here, it is the two big ones which will be changed.
  6. Apple Time Capsule Model A1254 - Replacing the power supply capacitors: adım 6, 1 resimden 1.
    • The capacitors are unstuck, straightened and ready to be unsoldered.
  7. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Replacing Capacitors: adım 7, 1 resimden 1.
    • The two new capacitors are in place.
    • WARNING: if during reassembly, the capsule goes into a "high temperature" alarm on Airport, with the fan running and the orange light flashing, this is probably due to contact between the "-" leg of the lower capacitor and the wire below.
    • To avoid the above problem, you have to put the small silicone tube removed from the old capacitor back, and don't hesitate to put a bit of nail polish to hold it together.
Sonuç
To reassemble your device, follow the instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Madcat
605 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Merci
Je vais tenter la réparation
Le temps d’acheter les condos
Beau Seck - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 65
Her zaman: 1,684
