Giriş
The base plate serves as the under casing for the device. It provide structural security and protection for the internal components. If the base plate is damaged it may put the internal hardware at risk and should be replaced. The rubber covering is held in place by an adhesive and make take some time remove.
Neye ihtiyacın var
Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
9 farklı kişi bu kılavuzu tamamladı.
