Ana içeriğe geç
Apple USB SuperDrive Optical Drive Replacement
Neye ihtiyacın var
  1. Apple USB SuperDrive Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement, Optical Drive: adım 1, 2 resimden 2.
    • To open the SuperDrive we must remove the lower case.
    • The lower case is attached by 8 clips.
    • 6 along the sides
    • 2 on the back
    <<Add the following>>
    Note: Here's a method to hack the OS-X configuration file for the SuperDrive to be used on the older iMac, MacBook, or MacBook Pro systems that the drive normally won't work with. Use with caution!
    open the com.apple.Boot.plist file in a text editor or in terminal use nano you will see a key <key>Kernel Flags</key>
    under it add the following line
    <string>mbasd=1</string>
    reboot your Mac
    Dan - Yanıt
  2. Apple USB SuperDrive Optical Drive Replacement: adım 2, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 2, 2 resimden 2.
    • Insert a metal spudger down between the black lower case and the aluminum upper case.
    • Lightly pry back to gently lift the clip out of place, just far enough to disengage.
    • Don't lift to far, or the clip on opposite side of drive will be wedged in place.
  3. Apple USB SuperDrive Optical Drive Replacement: adım 3, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 3, 2 resimden 2.
    • Repeat Step 2 for each of the 8 clips.
    • Continue until all of the clips have been disengaged and the lower case is free.
  4. Apple USB SuperDrive Optical Drive Replacement: adım 4, 1 resimden 1.
    • Lift off and set aside the lower case.
  5. Apple USB SuperDrive Optical Drive Replacement: adım 5, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 5, 2 resimden 2.
    • Remove the screws holding optical drive in the upper case
    • (A1270) three 3.8 mm with 1 mm deep head #00 Phillips head screws.
    • (A1379) 2 #00 Phillips head screws (I did not measure their length, sorry)
    • (A1379) 1 T9 torx screw
    On later models the bottom-right screw is a TR10 (Torx) screw.
    boelaars - Yanıt
    The 2 #00 screws in the A1379 are 3mm in length
    Mal - Yanıt
  6. Apple USB SuperDrive Optical Drive Replacement: adım 6, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 6, 2 resimden 2.
    • (A1270) Lift the optical drive from the thick side, then pull out.
    • (A1379) You will need to be even more careful with this model, as there is less wiggle room. Peel back the insulation tape to see the connector.
    • Be careful of the wires still running from the drive to case.
    • When re-installing the optical drive insert tongue in groove side first, as pictured.
    On later models the cable goes left instead of right, after entering the enclosure. This makes lifting the optical drive harder, but if done carefully it can still be done safely. The cables and the tape that fixes it in place is flexible and sturdy enough.
    boelaars - Yanıt
  7. Apple USB SuperDrive Optical Drive Replacement: adım 7, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 7, 2 resimden 2.
    • (A1270) Remove screws holding the board to optical drive.
    • two 3.8 mm #00 Phillips head screws.
    • (A1379) There are similar screws present here, but they only remove the metal shielding plate which gives further access to the USB wires
    • Unfortuantely, you cannot disconnect the drive any further without breaking out a soldering iron.
  8. Apple USB SuperDrive Optical Drive Replacement: adım 8, 2 resimden 1. Apple USB SuperDrive Optical Drive Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to remove the board from the optical drive.
    • The optical drive is now free from the case.
Sonuç
51 farklı kişi bu kılavuzu tamamladı.
Alex Jansen
9.176 İtibar
2 adet Kılavuz yazıldı
22 Yorum
After you pry open, inside there is an internal Super Drive.
Please tell me what's the markings/printed words model, name, brand, part number, etc....
Thank you.
gwen kent - Yanıt
My drive has nothing on that orange part in the middle of the drive (like you can see in the pictures here) except for two QR codes; it has absolutely no markings/printed words model, name, brand, part number, etc. on the inside, except the manufacturing date 2012 stamped inside the black aluminum bottom case cover.
Hope this helps.
cubanpete -
Thank you. My drive from 2012 ist fastened with a six-sided star-shaped Torx screw on the right side. The ones on the left side are black Philips screws and they are so tiny that they are hard to see in normal light. All I want to do is clean the drive from dust since it won't read DVDs anymore, while it has no problems with CDs at all. So now this Torx screw is another obstacle. I will have to waste more time & money buying an extra tool, thanks to Apple.
cubanpete - Yanıt
Is it possible to replace the internal DVD drive by a Bluray? Does macOS Sierra work with external Bluray drives?
Thanks for helping.
Sincerely
thomasli - Yanıt
Yes, but the only drive that is known to be an ATAPI (EIDE) connecting drive that supports Blu-ray is the Panasonic UJ-215-B. They were astronomically priced new in 2007-2008 when they were released. Good luck finding one today, and if you do it will still be very expensive and almost never a new one. But it seems to be a direct drop in replacement. I myself have already begun this project, and have one on the way right now. Bought it for $250 so it was pricey but considering it was new I got very lucky.
matthewknice -
Will any drive works? Is is SATA?
Philippe Morin - Yanıt
Nope, it's two different models- the first model was IDE, the second model has the USB cable soldered straight to the drive. Most unfortunate.
Josh Calvetti - Yanıt
Thanks Alex. If you want to clean the internals there are 4 screws holding the top of the drive. There is one a bit longer than the other three. Make sure you mark the hole for the longer one. Removing these screws and the top of the drive exposes all of the areas to be cleaned. Also, if anyone tinkers around with these and other computer devices even occasionally, it will make your tasks much easier if you buy the Ifixit Pro Tech Tool Kit.
Owen Gascoigne - Yanıt
Not sure why I wasn’t told till step 7 that I can not replace my optical drive because its soldered together. You can't just use another mac optical drive to replace it, they aren’t the same. Waste of time
Ryan Meyer - Yanıt
The guide does mention that there are two different versions in the introduction, and that if you have the newer version you’ll have to use an identical drive from another 2012 or later SuperDrive. It’s a stupid decision to be sure. Sorry it didn’t work out for you!
Josh Calvetti -
Does anyone have any information about the drive that I need for the soldered type drive. I can’t find out which drive to order. (part number or model number) I can find the earlier model drive, but not the newer drive.
kevs - Yanıt
Mine won't erase RW-DVD/CD and I was thinking in replacing the internals with a MacBook drive…
I probably will have it figured out before anyone answer but do they have the same interface?
Carlos Ferrari - Yanıt
Is there a replacement USB cable available for this unit? Bad design causes the section where it exits the case to get crunched. Need a replacement cable.
Thanks,
Andy
Andy Espo - Yanıt
Hey Andy,
unfortunately I do not think a replacement cable has ever been made available. On the later revisions the cable is soldered straight to the contacts on the drive- in theory, you could desolder it and re-solder the replacement, but there is no quick fix.
Josh Calvetti -
Is there a way to tell what version you have without tearing it down?
Stanley Smith - Yanıt
Directly on the bottom of the case itself.
matthewknice -
@swsmith1971. under the Apple (upper left hand corner) > about this Mac > System Report > SATA/SATA Express >. should be the top item
mayer - Yanıt
Can I replace usb A conector with usb C?
Parsa Meshkini - Yanıt
No, you can’t replace the connector, you can get an adapter which will allow the drive to connect to your USB-C Mac.
Dan -
Well, depending on your definition of "replace" you can surely solder in a USB-C cable, though one will have to figure out the best course of action with A) Removing the existing cable or B) Just soldering on a new USB-C plug (won't require disassembly).
Martin Winkelmann -
Just use a USB-A to USB-C adapter, don't hardwire the drive.
Dan -
In step #6, it can help to disconnect the "tongue" part (connected by two screws to the side of the internal drive) before removing the drive. When reinserting make sure that the part is properly inserted into the grooves of the silver case, one on the side and two small ones in the roof. When screwing it back onto the drive you will have to hold the drive up a bit so the screws will line up.
Martin Winkelmann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 88
Son 30 gün: 410
Her zaman: 80,276
