Giriş
Use this guide to open your Apple Watch SE for repairs.
You’ll need replacement adhesive to reattach the display when reassembling the device.
Before starting repairs, take your watch off the charger and power it down.
If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
To reassemble your Apple Watch SE, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
2 farklı kişi bu kılavuzu tamamladı.
