Ana içeriğe geç
Apple Watch Series 3 Adhesive Replacement
Neye ihtiyacın var
  1. Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: adım 1, 2 resimden 1. Apple Watch Series 3 Adhesive Replacement, Cleaning the gasket: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Adhesive Cleanup Kit (Set of 12)
    Satın Al
    • Apply a little bit of isopropyl alcohol (>99%) to a Q-tip or use a cleaning pad to gently remove the adhesive leftovers on top of the force touch gasket.
    • To remove the adhesive on the side where the display cables are running, fold down the display and carefully pull it away from the frame so there's enough space.
  2. Apple Watch Series 3 Adhesive Replacement, Cleaning the display: adım 2, 2 resimden 1. Apple Watch Series 3 Adhesive Replacement, Cleaning the display: adım 2, 2 resimden 2.
    • Flip the Apple Watch upside down so the display lays flat while lifting up the case.
    • Remove the leftovers on the back of the display.
  3. Apple Watch Series 3 Adhesive Replacement, Applying the new adhesive: adım 3, 1 resimden 1.
    • Use a pair of tweezers to carefully remove replacement adhesive with the blue protective film from the backing paper.
  4. Apple Watch Series 3 Adhesive Replacement: adım 4, 2 resimden 1. Apple Watch Series 3 Adhesive Replacement: adım 4, 2 resimden 2.
    • Hold the replacement adhesive diagonally to thread it over the display.
    • Slightly tilt the display forward so you can align the adhesive with the frame.
    • Position the replacement adhesive on top of the force touch gasket and use the pointed end of a spudger to move and press it into place.
  5. Apple Watch Series 3 Adhesive Replacement: adım 5, 1 resimden 1.
    • Reconnect the battery as seen in the replacement guide you came from.
    • Remove the protective film from the adhesive.
  6. Apple Watch Series 3 Adhesive Replacement: adım 6, 1 resimden 1.
    • Align the screen and press it down firmly onto the adhesive.
    • To improve bonding of the adhesive you can use an iOpener to warm up the display. Then apply some pressure for a few hours (placing it under one or two heavy books overnight might be a way).
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Bitiş Çizgisi
29 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
117.588 İtibar
188 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
7 Yorum
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
Ryan Hoover - Yanıt
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - Yanıt
Yes mine was also larger than the adhesive seal that is advertised here.
Nicholas Goldsworthy - Yanıt
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - Yanıt
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
Vangelis Angelakis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 76
Son 30 gün: 286
Her zaman: 25,156
