Ana içeriğe geç
Apple Watch Series 3 Screen Replacement
Neye ihtiyacın var
  1. Apple Watch Series 3 Screen Replacement, Power off your Apple Watch: adım 1, 2 resimden 1. Apple Watch Series 3 Screen Replacement, Power off your Apple Watch: adım 1, 2 resimden 2.
  2. Apple Watch Series 3 Screen Replacement, Apply heat: adım 2, 1 resimden 1.
    • Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
    • Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener, or move it around on the screen as sections cool, to heat the screen enough to pry it off.
  3. Apple Watch Series 3 Screen Replacement, Observe all warnings: adım 3, 3 resimden 1. Apple Watch Series 3 Screen Replacement, Observe all warnings: adım 3, 3 resimden 2. Apple Watch Series 3 Screen Replacement, Observe all warnings: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Safety Glasses
    $3.19
    Satın Al
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  4. Apple Watch Series 3 Screen Replacement, Pry up the screen: adım 4, 3 resimden 1. Apple Watch Series 3 Screen Replacement, Pry up the screen: adım 4, 3 resimden 2. Apple Watch Series 3 Screen Replacement, Pry up the screen: adım 4, 3 resimden 3.
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm).
  5. Apple Watch Series 3 Screen Replacement: adım 5, 2 resimden 1. Apple Watch Series 3 Screen Replacement: adım 5, 2 resimden 2.
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 3 Screen Replacement: adım 6, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 6, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 6, 3 resimden 3.
    • Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged.
    • Otherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
  7. Apple Watch Series 3 Screen Replacement: adım 7, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 7, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 7, 3 resimden 3.
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display to about a 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely.
  8. Apple Watch Series 3 Screen Replacement, Battery Disconnection: adım 8, 3 resimden 1. Apple Watch Series 3 Screen Replacement, Battery Disconnection: adım 8, 3 resimden 2. Apple Watch Series 3 Screen Replacement, Battery Disconnection: adım 8, 3 resimden 3.
    • Use a Y000 driver to remove the tri-point screw securing the metal cover plate.
    • Use a pair of tweezers to remove the cover plate.
    • First open the plate all the way to unhinge the two flaps.
    • Then close it halfway to remove it completely by lifting it out.
  9. Apple Watch Series 3 Screen Replacement: adım 9, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 9, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 9, 3 resimden 3.
    • On the GPS-only version it is possible to disconnect the battery immediately. For the cellular/LTE version, you need to disconnect the Force Touch gasket and fold it out of the way first, in order to disconnect the battery.
    • Disconnect the battery by prying its connector straight up.
    • Bend the connector up slightly to make sure it does not make contact by accident.
  10. Apple Watch Series 3 Screen Replacement, Screen: adım 10, 2 resimden 1. Apple Watch Series 3 Screen Replacement, Screen: adım 10, 2 resimden 2.
    • Use a pair of tweezers to peel off the tape covering the display cable connectors.
    • Start from the bottom right of the tape and carefully work your way towards the connector in the middle.
    • The tape can be stubborn, so take care not to pull too hard and damage the cables underneath. If needed, apply a little heat or some isopropyl alcohol to help soften the adhesive.
  11. Apple Watch Series 3 Screen Replacement: adım 11, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 11, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 11, 3 resimden 3.
    • The leftmost connector contains a piece of conductive foil, which may tear when taking off the tape.
    • If it tears, grab it from the bottom left to remove it completely. This way the matching foil underneath (on the display) will remain unharmed.
  12. Apple Watch Series 3 Screen Replacement: adım 12, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 12, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 12, 3 resimden 3.
    • Carefully use a pry tool or a clean fingernail to unlock the first of the three ZIF connectors by prying up the small black locking flap opposite the cable.
  13. Apple Watch Series 3 Screen Replacement: adım 13, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 13, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 13, 3 resimden 3.
    • Pry up the locking flaps on the remaining two ZIF connectors.
    • Replacement screens usually ship with these locking flaps closed. During reassembly, make sure the flaps are open before inserting the cables, or you may damage your watch.
  14. Apple Watch Series 3 Screen Replacement: adım 14, 3 resimden 1. Apple Watch Series 3 Screen Replacement: adım 14, 3 resimden 2. Apple Watch Series 3 Screen Replacement: adım 14, 3 resimden 3.
    • Use a pair of tweezers to disconnect the display flex cables by gently pulling them out.
    • If the cables are stubborn, try carefully walking them out in a left-to-right-motion while pulling gently.
  15. Apple Watch Series 3 Screen Replacement: adım 15, 1 resimden 1.
    • Remove the display.
    • For detailed reassembly instructions, including replacing the Force Touch gasket and surrounding adhesive, see the guide linked in the conclusion below.
Sonuç
Continue from Step 10 of our Force Touch Sensor guide to re-seal your watch and complete your repair. For best results, don’t connect your new display until after Step 16.
299 farklı kişi bu kılavuzu tamamladı.
Tobias Isakeit
117.217 İtibar
188 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.519 adet Kılavuz yazıldı
52 Yorum
“Replacing the display can cause issues with Apple Pay.“
If ApplePay could possibly be disabled by this procedure, then seems like a show stopper.
Is ApplePay still an issue?
Joel Weston - Yanıt
This is indeed something we can not rule out entirely. There are too many options to consider and we are not able to test all of them (type of replacement screen, software related issues with WatchOS and paired/unpaired watches. The NFC chip is the main issue here since it lives on the display and is responsible for Apple Pay. We are happy for any insight others can provide to offer a working solution/guide.
Tobias Isakeit -
I will try this once i get a display from iFixit. Thanks :) i hope it works
Kundan Agrawal - Yanıt
Apne display kaha se or kitne ka kharida , pls tel me
Honey Gothwal -
Hey guys, I replaced the screen and once I turned it on I got the green snake screen. When I try to charge it, it gets really hot now. Did I damage the battery or anything else?
Aaron - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 61
Son 7 gün: 342
Son 30 gün: 1,721
Her zaman: 365,308
