Ana içeriğe geç
Apple XServe Raid Battery Replacement
Neye ihtiyacın var
  1. Apple XServe Raid Battery Replacement, Raid Battery: adım 1, 2 resimden 1. Apple XServe Raid Battery Replacement, Raid Battery: adım 1, 2 resimden 2.
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: adım 2, 1 resimden 1.
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: adım 3, 1 resimden 1.
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: adım 4, 3 resimden 1. Apple XServe Raid Battery Replacement: adım 4, 3 resimden 2. Apple XServe Raid Battery Replacement: adım 4, 3 resimden 3.
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: adım 5, 1 resimden 1.
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: adım 6, 2 resimden 1. Apple XServe Raid Battery Replacement: adım 6, 2 resimden 2.
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: adım 7, 1 resimden 1.
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: adım 8, 1 resimden 1.
    • Lift the raid card battery out of the chassis.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cody West
234 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 724
