Ana içeriğe geç
Apple iPod Hi-Fi Batteries Replacement
Neye ihtiyacın var
  1. Apple iPod Hi-Fi Batteries Replacement, Batteries: adım 1, 1 resimden 1.
    • Put your coin in the battery lock on the back of the the Hi-Fi. Turn the coin to the left to release the battery panel.
    • Remove the battery panel with your hands.
    • You can also use a metal spudger or flathead screwdriver to open the battery lock instead of a coin.
  2. Apple iPod Hi-Fi Batteries Replacement: adım 2, 1 resimden 1.
    • Remove the six D batteries from the device.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Timothy Scheuermann
710 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G1
5 Üyeler
16 adet Kılavuz yazıldı
3 Yorum
good day.  Does the column charge the batteries when it is plugged in?
pay4e4ek777 - Yanıt
Nope, the hifi will not charge any batteries that are installed.
Josh Calvetti -
Hello, I realize these comments/texts are a bit old (2019) however, I have an Apple Speaker unit from 2006 that is practically new with very little usage but stopped working due to purchasing a Bluetooth adaptor and inserting it in the rear (Audio in) jack. It had been working “great” with the Bluetooth and my iPhone for a while until the speaker unit ceased to function-turn back on (no power). Can you kindly assist in assessing-determining what might have gone wrong and what would be required to fix this problem. Many thanks ahead. Look forward to your reply.
Roosevelt Adrianza - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 22
Son 30 gün: 107
Her zaman: 4,472
