Ana içeriğe geç
Apple iPod Hi-Fi Grille Replacement
Neye ihtiyacın var
  1. Apple iPod Hi-Fi Grille Replacement, Grille: adım 1, 1 resimden 1.
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: adım 2, 1 resimden 1.
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: adım 3, 1 resimden 1.
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Timothy Scheuermann
710 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S16G1
5 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,437
