Giriş
This guide details how to replace the front grille of the Apple iPod Hi-Fi speaker system.
Neye ihtiyacın var
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
5 farklı kişi bu kılavuzu tamamladı.
