Giriş
This guide details how to replace the power supply of the Apple iPod Hi-Fi speaker system.
Neye ihtiyacın var
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Unplug the 2 cables on the top of the power supply box.
Unclip the cables clipped together to the left of the power supply box.
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
It not just the power supply. The amplifier board is attached to the top.
Where can we find a compatible power suply? Thank you.
Bonjour le tutoriel est très bien mais ou peut-on acheter le bloc d’alimentation ?
Merci
where can i find a power supply please .
What is the Part Number of the Apple iPod Hi-Fi internal Power Supply and Amplifier Assembly?
