Ana içeriğe geç
Apple iSight Webcam Camera Replacement
Neye ihtiyacın var
  1. Apple iSight Webcam Camera Replacement, External Body Frame: adım 1, 1 resimden 1.
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Camera Replacement: adım 2, 1 resimden 1.
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Camera Replacement: adım 3, 2 resimden 1. Apple iSight Webcam Camera Replacement: adım 3, 2 resimden 2.
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Camera Replacement, Camera: adım 4, 1 resimden 1.
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Camera Replacement: adım 5, 2 resimden 1. Apple iSight Webcam Camera Replacement: adım 5, 2 resimden 2.
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Camera Replacement: adım 6, 1 resimden 1.
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Camera Replacement: adım 7, 1 resimden 1.
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Camera Replacement: adım 8, 2 resimden 1. Apple iSight Webcam Camera Replacement: adım 8, 2 resimden 2.
    • Gently pull out the ribbon cables at the base of the circuit board. The camera module and lens cap are connected to the board via two busses.
    • Make sure that all pins are loose before pulling them out or you could risk bending the pins or breaking the connector.
  9. Apple iSight Webcam Camera Replacement: adım 9, 2 resimden 1. Apple iSight Webcam Camera Replacement: adım 9, 2 resimden 2.
    • Remove the three PH000 3.55mm screws that connect the end cap that holds the privacy shutter to the rest of the camera enclosure. Once the screw are removed, you can pull them apart.
  10. Apple iSight Webcam Camera Replacement: adım 10, 2 resimden 1. Apple iSight Webcam Camera Replacement: adım 10, 2 resimden 2.
    • Unscrew the three PH000 3.55mm screws from the connecting plate and the camera enclosure. Pull apart when all screws are removed.
  11. Apple iSight Webcam Camera Replacement: adım 11, 1 resimden 1.
    • Unscrew the three PH000 3.55mm screws securing the Camera module circuit board and lens enclosure.
  12. Apple iSight Webcam Camera Replacement: adım 12, 1 resimden 1.
    • Pull the pin tab from the base of the circuit board to separate the camera module and the lens enclosure.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kaleb McArdle
175 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S5-G1, Baechle Spring 2018 IUPUI, Team S5-G1, Baechle Spring 2018 üyesi
IUPUI-BAECHLE-S18S5G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 2,712
