Ana içeriğe geç
Aquaris M5 Vibration Unit Replacement
Neye ihtiyacın var
  1. Aquaris M5 Vibration Unit Replacement, Back Cover: adım 1, 2 resimden 1. Aquaris M5 Vibration Unit Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 Vibration Unit Replacement: adım 2, 2 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 2, 2 resimden 2.
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 Vibration Unit Replacement: adım 3, 3 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 3, 3 resimden 2. Aquaris M5 Vibration Unit Replacement: adım 3, 3 resimden 3.
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Aquaris M5 Vibration Unit Replacement, Battery: adım 4, 1 resimden 1.
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  5. Aquaris M5 Vibration Unit Replacement: adım 5, 3 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 5, 3 resimden 2. Aquaris M5 Vibration Unit Replacement: adım 5, 3 resimden 3.
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  6. Aquaris M5 Vibration Unit Replacement: adım 6, 2 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 6, 2 resimden 2.
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  7. Aquaris M5 Vibration Unit Replacement, Front Camera: adım 7, 3 resimden 1. Aquaris M5 Vibration Unit Replacement, Front Camera: adım 7, 3 resimden 2. Aquaris M5 Vibration Unit Replacement, Front Camera: adım 7, 3 resimden 3.
    • FPC Connectors can break easily, be very careful.
    • Use an opening tool or your finger nail to open the FPC connector.
    • Disconnect the FPC connector cable.
    • Use the tip of a spudger to leverage the camera out of its housing.
    • Remove the front camera.
  8. Aquaris M5 Vibration Unit Replacement, Rear Camera: adım 8, 2 resimden 1. Aquaris M5 Vibration Unit Replacement, Rear Camera: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the flat side of a spudger to disconnect the camera's flex cable.
    • Use Tweezers to grab the camera and lift it out of the phone.
  9. Aquaris M5 Vibration Unit Replacement, Mainboard: adım 9, 3 resimden 1. Aquaris M5 Vibration Unit Replacement, Mainboard: adım 9, 3 resimden 2. Aquaris M5 Vibration Unit Replacement, Mainboard: adım 9, 3 resimden 3.
    • Use a SIM card eject tool, to eject the two SIM card slots on one side.
    • Use a SIM card eject tool, to eject the micro SD card slot on the other side.
  10. Aquaris M5 Vibration Unit Replacement: adım 10, 3 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 10, 3 resimden 2. Aquaris M5 Vibration Unit Replacement: adım 10, 3 resimden 3.
    Satın Al
    • Use tweezers to unplug the antenna cable in the bottom right of the mainboard.
    • Use a spudger to disconnect the two flex cables at the bottom of the mainboard.
  11. Aquaris M5 Vibration Unit Replacement: adım 11, 2 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the flex cable at the top of your the mainboard.
    • Bend the cable a bit over the edge, so it won't block the mainboard later, when you are taking it out.
  12. Aquaris M5 Vibration Unit Replacement: adım 12, 1 resimden 1.
    • Take out the 4mm Phillips #00 screw, holding the mainboard to the frame.
  13. Aquaris M5 Vibration Unit Replacement: adım 13, 3 resimden 1. Aquaris M5 Vibration Unit Replacement: adım 13, 3 resimden 2. Aquaris M5 Vibration Unit Replacement: adım 13, 3 resimden 3.
    • Insert the flat end of a spudger between the mainboard and the mid frame.
    • The best spot is on the right side next to the two SIM card slots.
    • Use the spudger to lever the mainboard.
    • Take the mainboard out of the phone.
  14. Aquaris M5 Vibration Unit Replacement, Vibration Unit: adım 14, 2 resimden 1. Aquaris M5 Vibration Unit Replacement, Vibration Unit: adım 14, 2 resimden 2.
    Satın Al
    • Insert the tip of a spudger underneath the vibration unit to loosen it from the adhesive.
    • Use tweezers to grab the vibration unit and take it out of the phone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Theo Mat
12.790 İtibar
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 328
