Ana içeriğe geç
Aquarium Filter Impeller Replacement
Neye ihtiyacın var
  1. Aquarium Filter Impeller Replacement, Impeller: adım 1, 3 resimden 1. Aquarium Filter Impeller Replacement, Impeller: adım 1, 3 resimden 2. Aquarium Filter Impeller Replacement, Impeller: adım 1, 3 resimden 3.
    • Remove the filter lid by pulling upwards.
  2. Aquarium Filter Impeller Replacement: adım 2, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 2, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 2, 3 resimden 3.
    • Drain the filter completely of water.
  3. Aquarium Filter Impeller Replacement: adım 3, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 3, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 3, 3 resimden 3.
    • Twist the motor component outwards away from the filter’s center by 90 degrees.
  4. Aquarium Filter Impeller Replacement: adım 4, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 4, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 4, 3 resimden 3.
    • Pull down to separate the motor from the filter.
    • Steady force is needed to separate the pieces.
    • Potential for device damage: Pull straight down to avoid damaging the rubber water seal.
  5. Aquarium Filter Impeller Replacement: adım 5, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 5, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, pull the damaged impeller upwards off the impeller shaft.
    • The impeller is magnetized to the shaft causing a slight resistance to the impeller's removal.
  6. Aquarium Filter Impeller Replacement: adım 6, 2 resimden 1. Aquarium Filter Impeller Replacement: adım 6, 2 resimden 2.
    • Fill the impeller cavity with water.
    • Potential for device damage: Avoid getting water on other parts of the motor.
  7. Aquarium Filter Impeller Replacement: adım 7, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 7, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 7, 3 resimden 3.
    • Swirl the cavity with a Q-tip to scrape off any build up of sand or organic material.
  8. Aquarium Filter Impeller Replacement: adım 8, 2 resimden 1. Aquarium Filter Impeller Replacement: adım 8, 2 resimden 2.
    • Drain the water and other contents of the cavity.
  9. Aquarium Filter Impeller Replacement: adım 9, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 9, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 9, 3 resimden 3.
    • Clean the shaft and the cavity with Q-tips dipped in vinegar in a scraping motion.
    • Potential for device damage: Avoid getting vinegar on other parts of the motor.
  10. Aquarium Filter Impeller Replacement: adım 10, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 10, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 10, 3 resimden 3.
    • Wipe the shaft and the cavity with a damp paper towel to remove vinegar.
  11. Aquarium Filter Impeller Replacement: adım 11, 2 resimden 1. Aquarium Filter Impeller Replacement: adım 11, 2 resimden 2.
    • Pick up the new impeller using tweezers.
  12. Aquarium Filter Impeller Replacement: adım 12, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 12, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 12, 3 resimden 3.
    • Lower the new impeller into the cavity so that the shaft runs through the center of the impeller.
    • The impeller should immediately magnetize.
  13. Aquarium Filter Impeller Replacement: adım 13, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 13, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 13, 3 resimden 3.
    • Swirl the impeller with tweezers to make sure the impeller can move freely.
    • The magnetism of the pieces should resist movement to a degree, but if you are unable to move the impeller at all, return to Step 5.
  14. Aquarium Filter Impeller Replacement: adım 14, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 14, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 14, 3 resimden 3.
    • Press the motor into the filter hole with the cord side facing outwards forming a 90 degree angle.
    • Steady force is needed to connect the pieces.
    • Potential for device damage: Push straight up to avoid damaging the water seal.
  15. Aquarium Filter Impeller Replacement: adım 15, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 15, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 15, 3 resimden 3.
    • Twist the motor inwards by 90 degrees to align with the filter.
  16. Aquarium Filter Impeller Replacement: adım 16, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 16, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 16, 3 resimden 3.
    • Refill the filter compartment to the water line.
    • The water line is indicated on side of the filter labelled as "Tank water level."
  17. Aquarium Filter Impeller Replacement: adım 17, 3 resimden 1. Aquarium Filter Impeller Replacement: adım 17, 3 resimden 2. Aquarium Filter Impeller Replacement: adım 17, 3 resimden 3.
    • Press the lid into the grooves on top of the filter.
Sonuç
Filter is now ready to be returned to your aquarium and plugged in for use. Clean the impeller with vinegar and water semi annually to increase its longevity.
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 28
Son 30 gün: 146
Her zaman: 5,146
