Ana içeriğe geç
Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement
Neye ihtiyacın var
  1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: adım 1, 2 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: adım 1, 2 resimden 2.
    • Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
    • You may have one or two valves depending on the installation of your system.
  2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 2, 1 resimden 1.
    • Press the black pressure release button on top of the filter housing.
    • Hold the button down for 5 seconds.
  3. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 3, 3 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 3, 3 resimden 2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 3, 3 resimden 3.
    • Unscrew the filter housing canister clockwise with a water filter housing wrench.
  4. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 4, 1 resimden 1.
    • Remove the dirty pre-filter and dispose of it.
  5. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 5, 3 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 5, 3 resimden 2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 5, 3 resimden 3.
    • Wash the filter housing canister with dish soap and water.
    • You may need a long-handled cleaning brush to scrub off dirt and debris.
    • Rinse and dry the filter housing canister.
  6. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 6, 1 resimden 1.
    • Remove the O-ring from the housing canister.
  7. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 7, 1 resimden 1.
    • Clean off old grease on the O-ring with a towel.
  8. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 8, 2 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 8, 2 resimden 2.
    • Replace the O-ring.
    • Apply Vaseline or lube around the seal.
  9. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 9, 2 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 9, 2 resimden 2.
    • Place the new pre-filter in the center of the filter housing canister.
  10. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 10, 2 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 10, 2 resimden 2.
    • Screw the filter housing canister counter-clockwise with your hands.
  11. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 11, 1 resimden 1.
    • Tighten the filter housing canister with the filter wrench.
  12. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 12, 2 resimden 1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 12, 2 resimden 2.
    • Turn on the water supply by turning the water valve(s) to be vertical, or parallel to the water pipe.
  13. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: adım 13, 1 resimden 1.
    • Run water in a sink or tub for 1-2 minutes to flush out the system and remove any air in the pipes.
Sonuç
Repeat steps every 2-3 months for best results.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 236
