Giriş
Use this guide to replace the 20-inch sediment pre-filter for your Aquasana F-300R 300,000-gallon whole house water filtration system.
The sediment pre-filter keeps rust, dirt, and sediment particles from entering the main filter unit.
After 2-3 months of use (when the pre-filter darkens or water flow slows), the sediment pre-filter must be replaced. When this pre-filter is not replaced in a timely manner, water pressure can drop, and sediment particles can enter and clog the main filter tank.
Neye ihtiyacın var
Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
Repeat steps every 2-3 months for best results.
Bir başkası bu kılavuzu tamamladı.
