Giriş
This guide will show you how to replace the motherboard in the Archos 101 G9 tablet.
The motherboard is a printed circuit board containing the principle components of a device, with connectors into which other circuit boards can be slotted. The motherboard serves as a single platform to connect all of the parts of a computer together. The motherboard connects the CPU, memory, hard drives, optical drives, video card, sound card, and other ports and expansion cards directly or via cables that connect to the device. Before starting this guide, make sure that your device is turned off and disconnect the device from any external power source.
Neye ihtiyacın var
Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
When you reach the corner, carefully pry the two halves of the device apart.
Repeat for the remaining three sides and corners.
Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
