Ana içeriğe geç
Archos Jukebox Recorder 20 Motherboard Replacement
Neye ihtiyacın var
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: adım 3, 1 resimden 1.
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: adım 4, 1 resimden 1.
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: adım 5, 2 resimden 1. Archos Jukebox Recorder 20 Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: adım 6, 1 resimden 1.
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: adım 9, 2 resimden 1. Archos Jukebox Recorder 20 Motherboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Desoldering Pump
    $3.99
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: adım 10, 2 resimden 1. Archos Jukebox Recorder 20 Motherboard Replacement: adım 10, 2 resimden 2.
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Sonuç
Shaun Rifield
121 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G3, Freund Spring 2018 IUPUI, Team S2-G3, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S2G3
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 469
