Ana içeriğe geç
Arlo Ultra 2 Spotlight Replacement
Neye ihtiyacın var
  1. Arlo Ultra 2 Spotlight Replacement, Battery: adım 1, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button on the bottom of the camera to release the housing.
    • Pull the white housing off the camera.
    FixBot'a Sor
    Yorum Ekle
  2. Arlo Ultra 2 Spotlight Replacement: adım 2, 1 resimden 1.
    • Pull the white cube shaped battery from the back to remove it from camera.
    FixBot'a Sor
    Yorum Ekle
  3. Arlo Ultra 2 Spotlight Replacement, Spotlight: adım 3, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement, Spotlight: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
    FixBot'a Sor
    Yorum Ekle
  4. Arlo Ultra 2 Spotlight Replacement: adım 4, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 4, 2 resimden 2.
    • Use a spudger to loosen and remove the camera faceplate.
    FixBot'a Sor
    Yorum Ekle
  5. Arlo Ultra 2 Spotlight Replacement: adım 5, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
    FixBot'a Sor
    Yorum Ekle
  6. Arlo Ultra 2 Spotlight Replacement: adım 6, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 6, 2 resimden 2.
    • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
    • The cable is very short and you will see it when removing the circuit board.
    FixBot'a Sor
    Yorum Ekle
  7. Arlo Ultra 2 Spotlight Replacement: adım 7, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 7, 2 resimden 2.
    • Use a spudger to gently pry the green circuit board away from the case.
    • Remove the green circuit board. This is your spotlight.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Yanıt Paylaş
Where can I buy a new spotlight for this camera?
Thomas Sanderhoff - Yanıt Paylaş
Thanks a lot. Took the LED from an old dead Ultra camera and it worked flawlessly.
Kristoffer - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 422
