Ana içeriğe geç
Arlo Ultra 2 Spotlight Replacement
Neye ihtiyacın var
  1. Arlo Ultra 2 Spotlight Replacement, Battery: adım 1, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement, Battery: adım 1, 2 resimden 2.
    • Press the button on the bottom of the camera to release the case.
    • Pull the white case off of camera.
  2. Arlo Ultra 2 Spotlight Replacement: adım 2, 1 resimden 1.
    • Pull the white cube shaped battery from the back to remove it from camera.
  3. Arlo Ultra 2 Spotlight Replacement, Spotlight: adım 3, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement, Spotlight: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
  4. Arlo Ultra 2 Spotlight Replacement: adım 4, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 4, 2 resimden 2.
    • Use a spudger to loosen and remove the camera faceplate.
  5. Arlo Ultra 2 Spotlight Replacement: adım 5, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 5, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4.00 mm black screws located across from each other above the camera lens.
  6. Arlo Ultra 2 Spotlight Replacement: adım 6, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 6, 2 resimden 2.
    • Use a spudger or your fingernail to flip up the small locking flap on the ZIF connector. Then, you can safely pull the cable out.
    • The cable is very short and you will see it when removing the circuit board.
  7. Arlo Ultra 2 Spotlight Replacement: adım 7, 2 resimden 1. Arlo Ultra 2 Spotlight Replacement: adım 7, 2 resimden 2.
    • Use a spudger to gently pry the green circuit board away from the case.
    • Remove the green circuit board. This is your spotlight.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Great tutorial, very helpful. A suggestion however would be to also offer for sale or add links to where the replacement components can be purchased. In this instance I could not find a replacement spotlight and had to buy a donor camera. Thanks
Gareth - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 113
