Ana içeriğe geç
ArmorAll AA255 Motor Replacement
Neye ihtiyacın var
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: adım 1, 1 resimden 1.
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
    FixBot'a Sor
    Yorum Ekle
  2. ArmorAll AA255 Motor Replacement: adım 2, 1 resimden 1.
    • Remove the five 15mm PH2 screws.
    FixBot'a Sor
    Yorum Ekle
  3. ArmorAll AA255 Motor Replacement: adım 3, 1 resimden 1.
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
    FixBot'a Sor
    Yorum Ekle
  4. ArmorAll AA255 Motor Replacement: adım 4, 2 resimden 1. ArmorAll AA255 Motor Replacement: adım 4, 2 resimden 2.
    • Gently separate the upper and lower sections of the main housing.
    FixBot'a Sor
    Yorum Ekle
  5. ArmorAll AA255 Motor Replacement, Motor: adım 5, 3 resimden 1. ArmorAll AA255 Motor Replacement, Motor: adım 5, 3 resimden 2. ArmorAll AA255 Motor Replacement, Motor: adım 5, 3 resimden 3.
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
    FixBot'a Sor
    Yorum Ekle
  6. ArmorAll AA255 Motor Replacement: adım 6, 3 resimden 1. ArmorAll AA255 Motor Replacement: adım 6, 3 resimden 2. ArmorAll AA255 Motor Replacement: adım 6, 3 resimden 3.
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
    FixBot'a Sor
    Yorum Ekle
  7. ArmorAll AA255 Motor Replacement: adım 7, 3 resimden 1. ArmorAll AA255 Motor Replacement: adım 7, 3 resimden 2. ArmorAll AA255 Motor Replacement: adım 7, 3 resimden 3.
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
    FixBot'a Sor
    Yorum Ekle
  8. ArmorAll AA255 Motor Replacement: adım 8, 2 resimden 1. ArmorAll AA255 Motor Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
    FixBot'a Sor
    Yorum Ekle
  9. ArmorAll AA255 Motor Replacement: adım 9, 2 resimden 1. ArmorAll AA255 Motor Replacement: adım 9, 2 resimden 2.
    • The motor is ready for replacement. Pull the motor to separate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
YeaJun Yoo
302 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G1
4 Üyeler
6 adet Kılavuz yazıldı
4Kılavuz Yorumları
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Yanıt Paylaş
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Yanıt Paylaş
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Yanıt Paylaş
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 77
Her zaman: 5,751
