Ana içeriğe geç
ArmorAll AA255 Switch Replacement
Neye ihtiyacın var
  1. ArmorAll AA255 Switch Replacement, Lower Motor Housing: adım 1, 1 resimden 1.
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
    FixBot'a Sor
    Yorum Ekle
  2. ArmorAll AA255 Switch Replacement: adım 2, 1 resimden 1.
    • Remove the five 15mm PH2 screws.
    FixBot'a Sor
    Yorum Ekle
  3. ArmorAll AA255 Switch Replacement: adım 3, 1 resimden 1.
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
    FixBot'a Sor
    Yorum Ekle
  4. ArmorAll AA255 Switch Replacement: adım 4, 2 resimden 1. ArmorAll AA255 Switch Replacement: adım 4, 2 resimden 2.
    • Gently separate the upper and lower sections of the main housing.
    FixBot'a Sor
    Yorum Ekle
  5. ArmorAll AA255 Switch Replacement, Switch: adım 5, 1 resimden 1.
    • Using a PH2 screw head, unscrew the two 15mm screws as shown.
    FixBot'a Sor
    Yorum Ekle
  6. ArmorAll AA255 Switch Replacement: adım 6, 3 resimden 1. ArmorAll AA255 Switch Replacement: adım 6, 3 resimden 2. ArmorAll AA255 Switch Replacement: adım 6, 3 resimden 3.
    • Pull the black handle.
    • Using a PH2 screwdriver, unscrew the single 12mm screw shown.
    FixBot'a Sor
    Yorum Ekle
  7. ArmorAll AA255 Switch Replacement: adım 7, 2 resimden 1. ArmorAll AA255 Switch Replacement: adım 7, 2 resimden 2.
    • Use the blue opening tool to open up the black handle.
    FixBot'a Sor
    Yorum Ekle
  8. ArmorAll AA255 Switch Replacement: adım 8, 2 resimden 1. ArmorAll AA255 Switch Replacement: adım 8, 2 resimden 2.
    • Using your fingers, gently take out the black cords.
    • Careful to not break the black cords.
    FixBot'a Sor
    Yorum Ekle
  9. ArmorAll AA255 Switch Replacement: adım 9, 2 resimden 1. ArmorAll AA255 Switch Replacement: adım 9, 2 resimden 2.
    • Using the spudger, take out the switch. Do this by pushing the spudger against the switch on both sides as shown and then pull the switch out.
    FixBot'a Sor
    Yorum Ekle
  10. ArmorAll AA255 Switch Replacement: adım 10, 1 resimden 1.
    • Replace the switch shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Renzo La Rosa
224 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016 üyesi
IUPUI-BAECHLE-S16S2G1
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Any idea where to find a replacement switch? I did not see one on Amazon or eBay.
Mitchell Taylor - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 80
Her zaman: 3,494
