Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Before replacing any components on the Arnova 7K G3 tablet, disassembly is required. That process starts with removing the rear cover to gain access to a majority of the components including the battery, speaker, and logic board.
  1. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet.
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  3. Place the iFixit opening tool in the notches between the cases and pull the covers apart. Place the iFixit opening tool in the notches between the cases and pull the covers apart.
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  4. Repeat step two until 3/4 of the rear cover is unlatched.
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
Sonuç
Tyler Sigafoose
210 İtibar
2 adet Kılavuz yazıldı
Takım
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G2
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 224
