Ana içeriğe geç
Arturia Microbrute Opening Procedure
Neye ihtiyacın var
  1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: adım 1, 2 resimden 1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: adım 1, 2 resimden 2.
    • Switch off the Microbrute and make sure to disconnect any cables.
    • Don’t forget the mini patch bay on the top right.
  2. Arturia Microbrute Opening Procedure: adım 2, 1 resimden 1.
    • Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
    • Use a screwdriver to remove the twelve Philips screws on the bottom plate.
  3. Arturia Microbrute Opening Procedure: adım 3, 3 resimden 1. Arturia Microbrute Opening Procedure: adım 3, 3 resimden 2. Arturia Microbrute Opening Procedure: adım 3, 3 resimden 3.
    • Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
    • Be aware of the ribbon cable connecting the keyboard to the PCB.
    • The cable should give you enough slack to put the top section over the keyboard section for better handling.
  4. Arturia Microbrute Opening Procedure: adım 4, 1 resimden 1.
    • Next, focus on the connector of the keyboard.
  5. Arturia Microbrute Opening Procedure: adım 5, 3 resimden 1. Arturia Microbrute Opening Procedure: adım 5, 3 resimden 2. Arturia Microbrute Opening Procedure: adım 5, 3 resimden 3.
    • Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
  6. Arturia Microbrute Opening Procedure: adım 6, 2 resimden 1. Arturia Microbrute Opening Procedure: adım 6, 2 resimden 2.
    • Grab the ribbon cable with your fingers and pull it out of the connector.
  7. Arturia Microbrute Opening Procedure: adım 7, 1 resimden 1.
    • Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
Sonuç
Tobias Isakeit
129.480 İtibar
189 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 305
