Ana içeriğe geç
Azpen A720 Back Cover Replacement
Neye ihtiyacın var
  1. Azpen A720 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Azpen A720 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Back Cover Replacement: adım 2, 3 resimden 1. Azpen A720 Back Cover Replacement: adım 2, 3 resimden 2. Azpen A720 Back Cover Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Back Cover Replacement: adım 3, 1 resimden 1.
    • Remove the rear casing.
Sonuç
Ben
280 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G3
2 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 388
