Ana içeriğe geç
Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
Neye ihtiyacın var
  1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: adım 1, 2 resimden 1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: adım 1, 2 resimden 2.
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: adım 2, 1 resimden 1.
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: adım 3, 2 resimden 1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: adım 3, 2 resimden 2.
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
Sonuç
To disassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Ashlie Reott
340 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G30
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 532
