Ana içeriğe geç
Assembling Parabolic Solar Cooker Tripod Base Stand
Neye ihtiyacın var
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: adım 1, 2 resimden 1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: adım 1, 2 resimden 2.
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
    FixBot'a Sor
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: adım 2, 1 resimden 1.
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
    FixBot'a Sor
Sonuç
To disassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ashlie Reott
340 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 üyesi
CPSU-AMIDO-F13S4G30
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
Paul Paul - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 902
