Ana içeriğe geç
Assembly of aerial socket outlet, European model.
  1. Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: adım 1, 3 resimden 1. Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: adım 1, 3 resimden 2. Assembly of aerial socket outlet, European model., SOCKET ASSEMBLY: adım 1, 3 resimden 3.
    • Assembly of an aerial plug socket (European) on a 1.5 m cable, removing the PC screen power socket (Recycling a cable for another use).
  2. Assembly of aerial socket outlet, European model.: adım 2, 1 resimden 1.
    • Disassembly of the aerial intake screw.
  3. Assembly of aerial socket outlet, European model.: adım 3, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 3, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 3, 3 resimden 3.
    • Identification of the terminals, we will connect Phase and Neutral at the 2 ends, ground at the central screw.
  4. Assembly of aerial socket outlet, European model.: adım 4, 1 resimden 1.
    • Unscrewed from the screws to open the connection point.
  5. Assembly of aerial socket outlet, European model.: adım 5, 2 resimden 1. Assembly of aerial socket outlet, European model.: adım 5, 2 resimden 2.
    • To cut the wire flush with the connector to be removed, we can use electrician's scissors, electrician's wire cutters, fine electronics wire cutters.
  6. Assembly of aerial socket outlet, European model.: adım 6, 2 resimden 1. Assembly of aerial socket outlet, European model.: adım 6, 2 resimden 2.
    • Cut flush, to take advantage of the full length of the cable
  7. Assembly of aerial socket outlet, European model.: adım 7, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 7, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 7, 3 resimden 3.
    • VERY IMPORTANT STEP, to avoid forgetting to insert the cover, (It has happened to all of us, not once, but more than once, it will be the first thing we insert).
    • We take the measurement of the piece of white hose to peel or strip, more or less about 2 cm, note that from one manufacturer of bases on plugs to another this measurement can vary.
  8. Assembly of aerial socket outlet, European model.: adım 8, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 8, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 8, 3 resimden 3.
    • With the scissors, CAREFULLY APPLYING ONLY LIGHT PRESSURE and turning in a circle, we will mark the stopping point to which it must be drawn.
    • To peel the cover carefully, we can do it with scissors.
  9. Assembly of aerial socket outlet, European model.: adım 9, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 9, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 9, 3 resimden 3.
    • Another peeling option is to make a slight cut with a utility knife and use fine electronic cutting pliers to help us.
  10. Assembly of aerial socket outlet, European model.: adım 10, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 10, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 10, 3 resimden 3.
    • We remove the white rubber cover, separate the wires, and without excessive pressure with the scissors, just marking the plastic, we proceed to strip it.
    • I like to rest the scissors on my thumb, as a fulcrum to be able to lever.
  11. Assembly of aerial socket outlet, European model.: adım 11, 2 resimden 1. Assembly of aerial socket outlet, European model.: adım 11, 2 resimden 2.
    • Inserted the cables into the connections and tightened the fixing screws.
  12. Assembly of aerial socket outlet, European model.: adım 12, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 12, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 12, 3 resimden 3.
    • Tight and fastening.
  13. Assembly of aerial socket outlet, European model.: adım 13, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 13, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 13, 3 resimden 3.
    • Personally, I like to apply a drop of petroleum jelly to screws that are inserted into plastic.
    • 1st It greatly facilitates the smooth insertion of the screw.
    • 2nd Avoid or minimize the plastic cracking or breaking, facilitating future disassembly of the plug socket.
  14. Assembly of aerial socket outlet, European model.: adım 14, 2 resimden 1. Assembly of aerial socket outlet, European model.: adım 14, 2 resimden 2.
    • "View of the assembled (one)."
  15. Assembly of aerial socket outlet, European model.: adım 15, 2 resimden 1. Assembly of aerial socket outlet, European model.: adım 15, 2 resimden 2.
    • Application of another drop of petroleum jelly where the closing screw will be inserted.
  16. Assembly of aerial socket outlet, European model.: adım 16, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 16, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 16, 3 resimden 3.
    • When the cover is on, the cover and the base have a specific mounting position; if it's upside down, it cannot be screwed in, and many cannot even be assembled.
  17. Assembly of aerial socket outlet, European model.: adım 17, 3 resimden 1. Assembly of aerial socket outlet, European model.: adım 17, 3 resimden 2. Assembly of aerial socket outlet, European model.: adım 17, 3 resimden 3.
    • Screw insert.
    • I hope this step-by-step guide is useful to you, as all aerial views of the socket are very similar.
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
es en
100%
redratchet21 dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Carlos López (España - Spain)
97.008 İtibar
342 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 38
Son 30 gün: 176
Her zaman: 1,762
