Ana içeriğe geç
Astak Mole Motor Replacement
Neye ihtiyacın var
    1. Astak Mole  Motor Replacement, Lower Case: adım 1, 1 resimden 1.
      • Remove the four bottom tabs in order to access the bottom screws.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole  Motor Replacement: adım 2, 1 resimden 1.
      • Remove all four 14 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. Astak Mole  Motor Replacement: adım 3, 1 resimden 1.
      • Remove the SD card.
      FixBot'a Sor
      Yorum Ekle
    4. Astak Mole  Motor Replacement: adım 4, 1 resimden 1.
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      FixBot'a Sor
      Yorum Ekle
    5. Astak Mole  Motor Replacement: adım 5, 1 resimden 1.
      • Gently pull back the motherboard to expose many of the component's wired connections.
      FixBot'a Sor
      Yorum Ekle
    1. Astak Mole  Motor Replacement, Electric Motor Assembly: adım 6, 1 resimden 1.
      • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
      • Screw Measurements: Length: 7.1mm
      • The motor should be free of its housing and only be attached to the motherboard by its wires.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole  Motor Replacement: adım 7, 1 resimden 1.
      • Sever motor connection to motherboard and remove wire carefully.
      • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Andrew Birch
204 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 767
