Ana içeriğe geç
Astak Mole Antenna Replacement
Neye ihtiyacın var
    1. Astak Mole Antenna Replacement, Lower Case: adım 1, 1 resimden 1.
      • Remove the four bottom tabs in order to access the bottom screws.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole Antenna Replacement: adım 2, 1 resimden 1.
      • Remove all four 14 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. Astak Mole Antenna Replacement: adım 3, 1 resimden 1.
      • Remove the SD card.
      FixBot'a Sor
      Yorum Ekle
    4. Astak Mole Antenna Replacement: adım 4, 1 resimden 1.
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      FixBot'a Sor
      Yorum Ekle
    5. Astak Mole Antenna Replacement: adım 5, 1 resimden 1.
      • Gently pull back the motherboard to expose many of the component's wired connections.
      FixBot'a Sor
      Yorum Ekle
    1. Astak Mole Antenna Replacement, Antenna: adım 6, 2 resimden 1. Astak Mole Antenna Replacement, Antenna: adım 6, 2 resimden 2.
      • Unscrew the antenna in a counter-clockwise rotation.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole Antenna Replacement: adım 7, 1 resimden 1.
      • Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
      • Screw length: 5.3mm
      FixBot'a Sor
      Yorum Ekle
    3. Astak Mole Antenna Replacement: adım 8, 1 resimden 1.
      • Gently pry open the circuit board attached to the antenna wire using a metal spudger.
      FixBot'a Sor
      Yorum Ekle
    4. Astak Mole Antenna Replacement: adım 9, 1 resimden 1.
      • Remove the antenna female end from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 933
