Ana içeriğe geç
Astak Mole Camera Head Replacement
Neye ihtiyacın var
  1. Astak Mole Camera Head Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Camera Head Replacement: adım 2, 1 resimden 1.
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Camera Head Replacement: adım 3, 1 resimden 1.
    • Remove the SD card.
  4. Astak Mole Camera Head Replacement: adım 4, 1 resimden 1.
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Camera Head Replacement: adım 5, 1 resimden 1.
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Camera Head Replacement, Camera Head: adım 6, 1 resimden 1.
    • Unscrew the three screws connecting the base to the camera head with the PH1 size Phillips head bit.
    • Screw measurements: Length=7.0mm.
    • The third screw can be exposed by rotating the camera head.
    • Do not force the camera head farther than it will allow you.
  7. Astak Mole Camera Head Replacement: adım 7, 1 resimden 1.
    • Unscrew indicated Phillips head screws using the PH1 Phillips head bit to free wires.
    • Screw measurements: Length=3.5mm
  8. Astak Mole Camera Head Replacement: adım 8, 3 resimden 1. Astak Mole Camera Head Replacement: adım 8, 3 resimden 2. Astak Mole Camera Head Replacement: adım 8, 3 resimden 3.
    • Separate the three indicated outputs from the motherboard with metal spudger.
    • There is electrical adhesive on the output. This can be easily separated with the metal spudger.
  9. Astak Mole Camera Head Replacement: adım 9, 1 resimden 1.
    • Separate the wire from CPU by cutting adhesive with metal spudger.
    • It is advised to reapply adhesive to wired connections during reassembly, and to re-attach wires to CPU to prevent disconnection and loose wires inside device.
    • Be careful not to damage the CPU in the process. This is not a wired connection.
Sonuç
Bryan
104 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 13
Her zaman: 549
