Ana içeriğe geç
Astak Mole Lower Case Replacement
Neye ihtiyacın var
  1. Astak Mole Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Lower Case Replacement: adım 2, 1 resimden 1.
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Lower Case Replacement: adım 3, 1 resimden 1.
    • Remove the SD card.
  4. Astak Mole Lower Case Replacement: adım 4, 1 resimden 1.
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Lower Case Replacement: adım 5, 1 resimden 1.
    • Gently pull back the motherboard to expose many of the component's wired connections.
Sonuç
Joseph Bello
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 357
