Ana içeriğe geç
Astak Mole Microphone Replacement
Neye ihtiyacın var
    1. Astak Mole Microphone  Replacement, Lower Case: adım 1, 1 resimden 1.
      • Remove the four bottom tabs in order to access the bottom screws.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole Microphone  Replacement: adım 2, 1 resimden 1.
      • Remove all four 14 mm Phillips #1 screws.
      FixBot'a Sor
      Yorum Ekle
    3. Astak Mole Microphone  Replacement: adım 3, 1 resimden 1.
      • Remove the SD card.
      FixBot'a Sor
      Yorum Ekle
    4. Astak Mole Microphone  Replacement: adım 4, 1 resimden 1.
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      FixBot'a Sor
      Yorum Ekle
    5. Astak Mole Microphone  Replacement: adım 5, 1 resimden 1.
      • Gently pull back the motherboard to expose many of the component's wired connections.
      FixBot'a Sor
      Yorum Ekle
    1. Astak Mole Microphone  Replacement, Microphone: adım 6, 1 resimden 1.
      • Remove microphone from its holder on the bottom section of the casing.
      FixBot'a Sor
      Yorum Ekle
    2. Astak Mole Microphone  Replacement: adım 7, 1 resimden 1.
      • Access microphone and assess damage.
      FixBot'a Sor
      Yorum Ekle
    3. Astak Mole Microphone  Replacement: adım 8, 1 resimden 1.
      • Remove microphone input with metal spudger. Be sure to sever electrical adhesive in order to separate input and output.
      • It is advised to re-apply adhesive to the cable once the new microphone cable is replaced.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Joseph Bello
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G2
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 492
