Ana içeriğe geç
Astro A20 Frame Replacement
Neye ihtiyacın var
  1. Astro A20  Frame Replacement, Frame: adım 1, 1 resimden 1.
    • Place your hand on the back of the speaker.
    FixBot'a Sor
    Yorum Ekle
  2. Astro A20  Frame Replacement: adım 2, 2 resimden 1. Astro A20  Frame Replacement: adım 2, 2 resimden 2.
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    FixBot'a Sor
    Yorum Ekle
  3. Astro A20  Frame Replacement: adım 3, 1 resimden 1.
    • Lift the speaker.
    • Disconnect the white connector from the device.
    • Remove the wires connecting the frame shown by the yellow square.
    • Pull the black cord through the hole shown by the blue arrow.
    FixBot'a Sor
    Yorum Ekle
  4. Astro A20  Frame Replacement: adım 4, 1 resimden 1.
    • Find the top 7mm J1 JIS head screws.
    • Remove the two 7mm J1 JIS head screws with a J1 screwdriver bit connected to a 60mm extension.
    • Pull the black cord through the frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jasmine Yarbrough
1.017 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 60
Her zaman: 3,468
