Ana içeriğe geç
Astro A20 Microphone Replacement
Neye ihtiyacın var
  1. Astro A20  Microphone Replacement, Cushion: adım 1, 1 resimden 1.
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
    FixBot'a Sor
    Yorum Ekle
  2. Astro A20  Microphone Replacement: adım 2, 1 resimden 1.
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    FixBot'a Sor
    Yorum Ekle
  3. Astro A20  Microphone Replacement: adım 3, 2 resimden 1. Astro A20  Microphone Replacement: adım 3, 2 resimden 2.
    • Remove the ear cushion from the headset.
    FixBot'a Sor
    Yorum Ekle
  4. Astro A20  Microphone Replacement, Microphone: adım 4, 1 resimden 1.
    • Place one hand on the back of the speaker.
    FixBot'a Sor
    Yorum Ekle
  5. Astro A20  Microphone Replacement: adım 5, 2 resimden 1. Astro A20  Microphone Replacement: adım 5, 2 resimden 2.
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    FixBot'a Sor
    Yorum Ekle
  6. Astro A20  Microphone Replacement: adım 6, 2 resimden 1. Astro A20  Microphone Replacement: adım 6, 2 resimden 2.
    • Lift the speaker area.
    • Disconnect the wires that connect the microphone.
    • Remove the 7mm screw with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Jasmine Yarbrough
1.017 İtibar
5 adet Kılavuz yazıldı
5Kılavuz Yorumları
worked for me….thanks
Thompson Crusher - Yanıt Paylaş
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Yanıt Paylaş
were? are you getting the new mic from? please link the site
jrod6t9 - Yanıt Paylaş
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 123
Her zaman: 15,701
