Ana içeriğe geç
Astro A20 Speaker Replacement
Neye ihtiyacın var
  1. Astro A20  Speaker Replacement, Cushion: adım 1, 1 resimden 1.
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
    FixBot'a Sor
    Yorum Ekle
  2. Astro A20  Speaker Replacement: adım 2, 1 resimden 1.
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    FixBot'a Sor
    Yorum Ekle
  3. Astro A20  Speaker Replacement: adım 3, 2 resimden 1. Astro A20  Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the ear cushion from the headset.
    FixBot'a Sor
    Yorum Ekle
  4. Astro A20  Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Place your hand on the opposite side of the speaker.
    FixBot'a Sor
    Yorum Ekle
  5. Astro A20  Speaker Replacement: adım 5, 2 resimden 1. Astro A20  Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    FixBot'a Sor
    Yorum Ekle
  6. Astro A20  Speaker Replacement: adım 6, 2 resimden 1. Astro A20  Speaker Replacement: adım 6, 2 resimden 2.
    • Lift the speaker area.
    • Disconnect the wires connected to the speaker.
    • Wedge a spudger on the edge of the speaker and lift upwards to remove the speaker from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jasmine Yarbrough
1.017 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 53
Her zaman: 9,381
