Ana içeriğe geç
Astro A20 Battery Replacement
Neye ihtiyacın var
  1. Astro A20 Battery Replacement, Cushion: adım 1, 1 resimden 1.
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
    FixBot'a Sor
    Yorum Ekle
  2. Astro A20 Battery Replacement: adım 2, 1 resimden 1.
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
    FixBot'a Sor
    Yorum Ekle
  3. Astro A20 Battery Replacement: adım 3, 2 resimden 1. Astro A20 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the ear cushion from the headset.
    FixBot'a Sor
    Yorum Ekle
  4. Astro A20 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Place hand on the opposite side of the speaker.
    FixBot'a Sor
    Yorum Ekle
  5. Astro A20 Battery Replacement: adım 5, 2 resimden 1. Astro A20 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
    FixBot'a Sor
    Yorum Ekle
  6. Astro A20 Battery Replacement: adım 6, 1 resimden 1.
    • Lift and remove the speaker from the headset.
    FixBot'a Sor
    Yorum Ekle
  7. Astro A20 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Astro A20 Battery Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard to expose the battery.
    FixBot'a Sor
    Yorum Ekle
  9. Astro A20 Battery Replacement: adım 9, 1 resimden 1.
    • Remove the battery with a plastic spudger.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jasmine Yarbrough
1.017 İtibar
5 adet Kılavuz yazıldı
3Kılavuz Yorumları
Does it work for Astro A20 2nd Gen too?
Charly - Yanıt Paylaş
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
Miguel Garcia - Yanıt Paylaş
That head set is A20 gen1 but main board in right side
from 7th pic that is right side
If you have no idea which is left side or right side.
just check where is buttons
Leo Lee - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 42
Son 30 gün: 194
Her zaman: 20,678
