Ana içeriğe geç
Astro A20 Battery Replacement
Neye ihtiyacın var
  1. Astro A20 Battery Replacement, Cushion: adım 1, 1 resimden 1.
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20 Battery Replacement: adım 2, 1 resimden 1.
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20 Battery Replacement: adım 3, 2 resimden 1. Astro A20 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the ear cushion from the headset.
  4. Astro A20 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Place hand on the opposite side of the speaker.
  5. Astro A20 Battery Replacement: adım 5, 2 resimden 1. Astro A20 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20 Battery Replacement: adım 6, 1 resimden 1.
    • Lift and remove the speaker from the headset.
  7. Astro A20 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the two 7mm screws with a Phillips #1 screwdriver.
  8. Astro A20 Battery Replacement: adım 8, 1 resimden 1.
    • Lift the motherboard to expose the battery.
  9. Astro A20 Battery Replacement: adım 9, 1 resimden 1.
    • Remove the battery with a plastic spudger.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jasmine Yarbrough
1.017 İtibar
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Does it work for Astro A20 2nd Gen too?
Charly - Yanıt
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
Miguel Garcia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 210
Her zaman: 17,936
